I need to print how to assemble a bissell proheat shampoorer
First locate screw pack (you will need a Phillips screwdriver). 2 long Phillips screws with hex nuts, 2 short Phillips screws. Should be taped to under part of handle.
2, Put upper handle into lower handle.
3, feed the power cord through the tool caddy from the flat side. Place caddy to handle so the hex shaped holes on upper portion.
4. Place the hex nut in the hex shaped hole and insert long bolt through the front of the handle. Do the same on the other screw and tighten them snuggly. Be careful not to over tighten them.
5. Insert small screws into lower 2 holes through the back side of the lower hose rack. Turn until tightened.
6. Attach tool(s) (that would be a small brush or the pet brush attachment to end of hose and on the attachment holder on front of upper handle.
7. Wrap hose around large holder closest to handle and power cord is wrapped around outer holder with rotating clamp.
Hope that helped
