Stove is about 5 years old and burners on top work fine.
SOURCE: Stove keeps shutting off by itself
HI I have a different brand, but this same thing was happening to our oven, I had to have a repairman replace the temperature sensor in the oven. Apparently it was reading the temperature as like 300 degrees higher than it actually was so it was shutting off (I guess as a safety mechanism). Hope this helps. Good luck.
SOURCE: BAKE MODE NOT WORKING ON MAYTAG STOVE
the gas valve has gone bad change the gas valve and the glow bar (igniter) at the same time.or you WILL have problems in the future
SOURCE: Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
SOURCE: burner igniter won't click or work
This is an easy problem to fix. If your repair man is correct and it is the spark module and not a wire harness problem you can pick up a spark module as sears for about $37 and it only takes a couple of minutes to install. Just pull off the back panel and replace the module. This is a repair that anyone can do. I would recommend unplugging the unit before replacing.
SOURCE: I have a maytag mgr4452bdw gas stove.The top
I HAVE A MGR4452BDW AND THE OVEN WILL NOT COME ON, THERE IS A GLOW AND THE GAS FILLS THE ROOM
