We are noticing an error message displayed on LG tromm washer model # wmt2778w
what is it and what could be teh reason ? how to fix it ?
thanks for the help.
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
My washer is stating OE what does that mean.
Hi there le means there is a small hole in the pressure tube where it joins onto the pressure switch this is caused by the ballist weight jumping up and chaffing the tube , simply cut off about one cm of the affected tube and refit.
hope this is of some help.
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective.
IE error code is Inlet Error, the solenoid valve on the water inlet is faulty.
OE error code is Overflow Error is a draining problem, normally caused by the drain pump.
Are you using he detergent
it said LE nothing more thanks
It says LE on the screen
UE flashing, washing stopped
mine says ce and not working . what is that mean?
0e error message
