Very frustrated. Also sound problems. Please help at least getting remote to work again
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
SOURCE: remote stop working
You should verify if the remote has failed. Contact the support for Vizio, or ask your dealer where you can buy original replacement accessories.
Visio Tech Support:
http://www.vizio.com/support.aspx?id=1586
Most of the time, we've seen the remote fail. Sometimes we are able to service the remote. Sometimes, the IR LED and or the crystal fails in the remotes. If it is more than this, it is impossible to have internal service parts for most remotes. It takes service experience to be able to change these parts.
On rare occasions the IR remote sensor and remote processor area in the set can have a failure. It is best to try another remote to verify this before sending the set for service.
The most common causes of failure of a remote controller is dropping, rough handling, getting food and drink inside, or putting the batteries in backwards.
Jerry G.
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
