I'm setting up Chromecast and having problems. On chromecast trouble shoot it says: In order to resolve this issue, you will need to disable AP (access point) isolation, AP isolation (also known as 'Client Isolation' or 'Guest Mode'), on your router. How do I do this?
SOURCE: This is for the WL-330gE
Don't you need another router or something if you use this one as a repeater?
SOURCE: I have a new Asus
Welcome to Fixya
Doing a hard reset should solved the issue and gain control again of the router. Could you check the properties of your LAN you might have put IP address, subnet mask and default gateway theren. Make sure that all settings are set to Obtain IP address automatically including the DNS. Try to clear the internet cache of your system.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I have set up this device as an AP and connected
Search in google about how to set up a DHCP server for your router and clone the modem's MAC address, most routers have this option, the thing is some ISPs limit the use of internet to only one machine, by cloning the modem's MAC address in your router you'll make the ISP believe there's only one machine connected to the Internet.
By setting up a DHCP server in your router you'll use only one IP to connect all machines using a private network, that should solve your problems.
Try both alternatives, and see which one works.
Please check the legal limitations of this procedure for your country or state and have a nice day! ;)
