Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
A
Anonymous Posted on Jul 15, 2014
Door switch light is on, door opens, fill machine with cloths, but the machine will not start.
5 Related Answers
Anonymous
  • Posted on Sep 21, 2008
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Jimster
James Greene
  • 240 Answers
  • Posted on Nov 16, 2008
SOURCE: Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Anonymous
  • 4 Answers
  • Posted on Dec 13, 2008
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Anonymous
  • 1185 Answers
  • Posted on Jun 06, 2009
SOURCE: Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Anonymous
  • 56 Answers
  • Posted on Feb 11, 2010
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
The door wouldn't open we found the manual release opened it hoping to start the load of clothes again. The lights go on but the machine doesn't start a cycle. Any suggestions?
Make sure that the door switch is closing properly. If not, and it is stuck in the "open" position, the unit will not operate. Try bypassing the switch to see if it then runs.
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
I have caught a piece of clothing in the door started the machine and water has started leaking out the door turned off the machine the machine has stopped leaking but I can't open the door have waited...
hello there is a way but it only works on some machines you need 2 people you have to tip the machine on side slightly the other person has to reach underneath and manually unlock it. it a fiddler thing to do but it might work hope it helps
regards
shaun
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Washer is filling up with to much water...
possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
3answers
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Door won't open and no error lights
sounds like the door interlock is manfunctioning.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
