Generally the defrost drip system is designed to evaporate the defrost water as the compressor fan runs as the forced warm air from the compressor evaporates the water in the tray. As long as the defrost timer is working properly and the compressor fan hasn't failed, you should never have to worry about emptying the tray.
Now, if it's overflowing you will need to determine why, is it the compressor fan, room temperature too cold, defrost cycle not working or what. The tray is usually located behind the grill at the bottom of the refrigerator which just pops off sometimes after opening the door(s). The tray sits in a recess where you lift it out of.
