The lights in the control panel are out most of the time, they occasionally turn on (both clock and oven) when the right front burner is hot so this makes me think it is a loose wire. Need to remove the panel and check but don't have a manual.
SOURCE: Burners Blew
I had a similar problem while mine was still under warranty. Seemed like every time I used the oven and stove top for a major dinner it would short out and I would get an error code: F1:E6. They replaced the board under the display area, but it happened again about 6 months later. Turned out that when they made the oven they didn't insert a chimney like vent system from the bottom left side of the oven to the vent holes that come out the upper left side of the stovetop. This caused the panel to overheat and stop the entire oven from working. They replaced the board again and installed the "chimney vent system" and I haven't had the problem occur again (it's been 3 years!).
SOURCE: Oven wont heat up.
after ignitor glows burners should fire within 30-60 seconds .if not your ignitors are weak (drawing less than 3.5 amps) and should be replaced Hope this helps ,please rate my solution :)
SOURCE: The right front burner light stays on even when I
One of your switches is bad. It is not unsafe just annoying. You can open the control panel and remove one PILOT wire from each switch. When the light goes out, that will be the bad switch. Before you do this,turn off the power to the range. After you remove the pilot wire(which controls the light) plug the range back in. If the light is out,that is your bad switch. If the light is not out,unplug the range,replace the wire you removed,then remove the next wire on the next switch. Plug the range back in. Repeat this process until the light goes out. When it does,that is the switch that needs replacing.
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
