I am unable to start a load and I get the same message over and over.
SOURCE: lid was not open
This washer has 2 hidden switches controlled by magnets. you cannott bypass them. they must be replaced.
SOURCE: Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
SOURCE: I have a Maytag Neptune top load washer touch
I no longer need a solution. My son took the lock off and put it back on, and the machine started working again.
Thanks you so much.
SOURCE: I loaded my washer (a
You have lost signaling thru ther left hand lid lock see if this post will help,
http://www.fixya.com/support/t6408618-op_stand
SOURCE: My washer has been stopping
The lid switch will need a slight adjustment to properly activate, or you could bend the raised bump on the back of the lid out a bit so it activates the switch better.
