Water trickling out even though new filter was installed properly
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
SOURCE: water dispenser is flowing super slow
It's likely a blockage in the tubing that brings the water from the house plumbing. Another possibility would be a clogged water filter, if the refrigerator has one.
The first place to start checking for water flow is the valve where the refrigerator supply tube connects to the house water supply. These small valves very easily clog with mineral deposits. If there is no blockage there, it is probably somewhere in the tubing which runs within the refrigerator. I have used plastic weedeater line to open up blockages in these tubes.
SOURCE: No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
