SOURCE: Ice maker is dripping into ice bin after water refills?
I had this problem on my refrigerator. I talked to a service tech at the local appliance dealer and here's what he said. There is a valve at the back of the refrigerator (mine is a side by side, but the basics are the same When the Ice maker goes thru it cycle, a part of that cycle is to turn on the water to fill the ice tray, then the next portion of that cycle is to turn off the water. What is happening is that the valve is getting the signal to close but due to mineral build up on the valve surface it is not able to completely shut off.
The solution is to replace the valve. This is not difficult. Turn off the water to the refrig. It's usually runs under the cabinets to the sink and you can see a plastic hose under there with a small handle you can turn to shut it off. Pull the refrig out so you can get to the back and you will see the valve. It will be connected to the same hose that is under the sink Remove and replace the valve. make sure all the little hose fittings are tight. Turn on the water under the sink and check for leaks.
Hope this helps PS you can get a new valve at most any appliance dealer.
Good luck Loringh
SOURCE: ice maker drips water
In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
SOURCE: outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the
water supply comes in is probably leaking. disconnect the water line coming out
of it and see if you have a slow drip. Try the dispenser to see if it's just
drips after use.
ice maker - If it overfills and drips, look for an
adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water
inlet valve on the back where the house water supply comes in.
SOURCE: Ice Maker drips water at head end
There is a small set screw that you can adjust to control the inlet
valve. Take off the front cover and look for the adjusting screw on the
side panel. It usually has arrows indicating it if for adjusting.
There is a picture here:
Have a look at this : http://www.davesrepair.com/DIYhelp/DIYicemakertips.htm
