During rinse cycle the washing machine stops
SOURCE: lg wm2032hw
check the pump filter and if necessary clean it up.
if you stop the programme and hold the start/ pause button for 3-5 sec the programme will cancelled and the drain will work.
if you hear a slow noise from the pump it may be blocked with external objects from your clouthes pocket,
so you need to contact a repairman.
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain
or work 'cause your outlet filter is clogged or an unusually heavy
load. The small door is on the left side front bottom of your washer.
Remove the door with a putty knife or thin butter knife inserted in the
middle top of the access panel door. Drain the water from the filter
housing by pulling the tube out of the clip and unplugging, allow it to
run into a bucket while the machine is in spin only mode. This mode is
acheived when the washer is first powered on press the spin button
until no spin is reached then run. Run in this mode until no water is
draining from the tube in the bucket. Keep the tube as low as possible.
When water has stopped coming out of the tube turn off the washer and
unplug from the wall. This step is important because this resets the
fault. Expect some water to come out when you open the filter housing
by turning counterclockwise until you can pull the filter from its
housing. Clean out your filter, return to housing turning clockwise
until seated and recap the tube and place in the holder, refit the
cover and plug back into the wall. Fixed. You may also need to lighten
the load a bit but I always try full on load anyways. If it fails again
just lighten, unplug wait >1 minute then replug and run.
Thanks.
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: my lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
