Taylor digital scale, Model # 5721F
Taylor electronic scales are designed to measure your personal weight, as well as your body fat and water weight. Your scale will measure in either pounds or kilograms, indicating your weight to the nearest ounce or gram. You can use the scale as a weight only device or you can take advantage of its bells and whistles by completing the programming process. The scale will store data for up to 10 users. Setup takes only a few minutes.
Set the scale to your choice of kilograms or pounds. The default measurement for the scale is pounds/inches. To change this setting, change the switch on the underside of the scale to kilograms.
Some electronic scales actually can be toggled between pounds and kilograms. A user guide to that scale might show how to do this but it likely would be done by pressing a button somewhere on the scales. . Other mechanical scales may simply have the conversion painted on the display.
Here is a webpage where you can just enter the figures and the conversion will be made.
https://www.metric-conversions.org/weight/kilograms-to-pounds.htm
I have a produex glass scale that is silver with a solid black stripe on one side and rows of poka dots on the other side. It has a tiny swicth on the back that changes the scale from pounds to kilograms.
