Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
SOURCE: fitting washing machine boot gasket/door seal
If you don't already have the part go to an appliance store to order it and ask for the instructions.
SOURCE: bosch washing machine error code
I've had the same problem, when we had a power cut I opened the door and after that I could only got F21 flashing! ,I googled for the answer and this WORKED:
Turn programme switch to 6 o clock,hold RPM button turn switch to spin, release RPM button
SOURCE: if filter cap is broken how do i open it on my bosch washing mach
I had the same problem. If it's stuck you may want a tool. I ended up using a pair of pliers on this plug. You may want to use a pair of vice-grip locking pliers and put a piece of thick metal on each side so you don't break the plug any worse (about 1/2" X 2" plate). MAKE SURE YOU TURN COUNTER CLOCKWISE! Wiggle it back and forth as you may have a wire or hairpin half in and half out of the pump filter area. It takes 2 full turns to get past the threads in order for the plug to come out. I had an underwire from a bra that gave me the worst problem. I worked on it for almost an hour. I have found change, jewelry, hairpins, BBs, small rocks, and a 4" long underwire from a bra. Please rate my solution if this gives you enough details to complete your task. THANKS!!
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
