Washing Machines Logo
A
Anonymous Posted on Jul 12, 2014
How to replace the drain pump on a WM2801HRA?
Ldf7932st not draining
In many cases the dishwasher will stop draining or draining fully due to a clogged drainage hose or due to an object caught in the draining pump. There are some cases when the draining pump is faulty and needs to be replaced. We have assembled the top issues to check for a dishwasher that does not drain.
  • Drain Pump: The drain pump pushes water through the drain hose. If the drain pump motor is malfunctioning the dishwasher will not drain. Drain pumps can be checked with a multimeter. If there is no continuity then it must be replaced with a new part.
I found this info at:
https://www.electrafixbc.ca/appliances/dishwasher.html
Check it out for more help with your diswasher issue. Good luck!
My dishwasher will not empty
In many cases the dishwasher will stop draining or draining fully due to a clogged drainage hoses or due to an object caught in the draining pump. There are some cases when the draining pump is faulty and needs to be replaced. We have assembled the top issues to check for a dishwasher that does not drain.
I got this info from:
Check it out for more help with your dishwasher issue.
Nov 02, 2019 • Dishwashers
Washer not draining
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
I need to find the reset button. It will not drain. This has happened before but I can't remember where the reset button is.
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
I have a Whirlpool Ultimate Care II washer Model#LSB6300LW0 that would not completely dry the clothes on the spin cycle. I'm not sure if the unit was spinning fast enough. I replaced the lid switch and...
It sounds like your Drain pump has either become clogged, or has burned out.
  1. First, disconnect the power to the machine.
  2. The drain pump is located at the bottom of the machine. You will have to remove the panel to access the drain pump, or you can access the drain pump from the bottom of the machine after you have removed the water from inside the machine.
  3. The drain pump has 2 hoses connected to it, and a wiring harness.
  4. Disconnect the hoses and wiring harness and remove the drain pump.
  5. Check the impeller inside the drain pump for coins, socks, etc. and clean it out if you can. Make sure it turns with ease, and isn't worn out, or rocking back in forth. If it is worn out, replace the drain pump.
  6. If after clearing the drain pump and reassembling, and the machine still fails to drain, replace the drain pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
My Whirlpool Imperial Series washing machine will not drain. It was recently moved from another home. Where and what should I start checking first.... ?
  1. Check the voltage going to the drain pump, and replace the drain pump if it is found to be bad.
  2. If you are getting no voltage to the drain pump, your control board or drain pump wiring may have been damaged.
  3. If the machine fills up with water, but doesn't drain, this is usually fixed by replacing the drain pump, un-kinking and clearing out the drain hose, or cleaning the drain pump and hoses out.
My whirlpool washer agitates but will not pump out the water. I thought the timer switch assembly was bad so I replaced it. Still no water pump. I can not find the Model Number tag on the washer...
Drain Pump Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
2helpful
My Kenmore HE 2t washer, model #110.47561600 appears to not be draining correctly. Previously to this problem the display showed errors of F-21 and 5-d (or "suds"). Also, the drain pump makes a...
It is possible to have something lodged in the drain pump and commonly happens. If the drain pump does not have anything in it then I would say replace it.
F21 Fault Code Repair
Wont power on after replacing drain pump.
could be just the fuse, but failing that check all circuit boards for signs of blowing or burns, some machines when there is a short on the pump blow the circuit on the timer which is the most expensive part to replace best of luck
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
