SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
SOURCE: My Hobart Handler 120 needs a .045 wire drive Wheel.
Locate your locale Hobart welding distributer, or contact hobart, the are nice people and will give you all the avice you need.
SOURCE: Have Hobart 140 Handler, The
You need to look at the wiring diagram to see what parts could be causing the problem. I had a 120 that did the same thing and it was the bridge rectifier that was bad. I unhooked my motor and hooked it to my battery charger to see if it was good.Hope this helps. I will see if I can find a diagram to look at and check back later to see if you have fixed the problem.
SOURCE: New Hobart Handler 140, feeds wire properly, but
Check the two main diodes. These units have a light duty cycle. About 20% if I remember correctly. I have one that I was welding with for a considerable amount of time, and burned up the diodes. You can test them by disconnecting the wires (with unit disconnected) and use a ohm meter. You should get a reading in one direction, but not the other. If no reading, then the diode is blown. You can order new ones from your local welding shop. Also check all conections on the secondary for any signs of overheating and loose connections.
Testimonial: "I appreciate the quick response. I failed to mention that this was my first time using a mig welder. Pulling the trigger fixed the problem. Thanks"
