SOURCE: f2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
SOURCE: what does error code F2E0 mean?
Hi
Thanks for using FixYa. Error F2-E0 in your Kitchen
Aid range indicates shorted keypad. To resolve this issue you’ll have to
replace the electronic range control (ERC). Please do rate the solution if
the issue is resolved or post a comment for further assistance.
Thanks
Rylee
this is the procedure for this code,
F2
Keypad
E0
E1
STUCK KEY (shorted key)
KEYPAD DISCONNECT or KEYPAD DISCONNECTED
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart to enter the
Diagnostics mode.
A. Unplug range or disconnect power.
B. Check that the keypad is firmly connected.
C. Plug in range or reconnect power.
D. Observe for longer than 1 minute.
E. If error remains then go to step F.
F. Unplug range or disconnect power.
G. Replace keypad.
H. Plug in range or reconnect power.
I. Observe for longer than 1 minute.
J. If error remains then go to step K.
K. Unplug range or disconnect power.
L. Replace display board.
M. Plug in range or reconnect power.
All parts come with a 365 day, any part, any reason return policy.
