Check for a fuel obstruction, sounds like urs starving for fuel, test or check your lines, fuel pump, any valves, etc are free and clear. I hope this helps!
Full tune up and carb clean .get new plug,air filter.oil Chang ,carb clean and adjustment.that should do it.,., try fuel filters and test fuel pump see if it's functioning properly.,.
Have your fuel pump checked. The wires on mine were melting due to the regulator attached the pump being bad so when the mule would first start it would run fine until it warmed up and then no gas
once the wires warmed up. Don't buy the Kawasaki replacement unless you want to pay $300 or more for the part (They are crazy over-priced on parts) and labor. Got a 3rd party pump for $50 and had it replaced for one hours labor and we are good to go. Worse case next time around I buy another $50 pump and replace it myself
