Model y2h21k46
SOURCE: Every time I engage my blades it Boggs down. It
Something is wrong with the blades mechanism - it opposes too much resistance to the motor and the motor can't deliver enough torque to compensate so it boggs down.
You will need to inspect the entire mechanism and look for rusted and/or seized parts. Also check the belt and its tensioner for proper functioning status. Also check the clutch for loose friction pads .
SOURCE: Husquavarna GT2254 runs fine till I try to engage the blades,
Hello janec37415:
>>From your Description it Sounds like the Seat Safety Switch is Bad, has a Bad Connection or the Stator/Charging Coils are Not Charging Enough for the PTO to be Engaged.
>>When the Blade is Engaged, the Seat Switch is Showing No One is on the Seat so the Engine is Shut Off by the Safety System or
>>When the PTO is Engaged and the Stator/Charging Coils are Not Charging Correctly, the Carburetor Solenoid Does Not get enough Voltage to Stay Open and the Engine Quits.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
SOURCE: Engine runs good and blades turn fine but the
the freewheel control is in the wrong position. push in all the way for mowing. This control is located on the rear of the mower below the seat.
SOURCE: release brake engine dies engage blades engine dies
there is a saftey switch on the deck that has shorted out need to replace
SOURCE: Model Rider155 Will mover slowly back and
Hi aywon,
These symptom point to the engine speed being set too low.
If adjusting the engine speed does not help, check to be sure your mower deck isn't too low. Also, the chute could be blocked.
Most probably the engine speed should be set higher.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
