My power light blinks red three times and tv will not turn on
SOURCE: Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: blinking red lights
Take out all the cables (HDMI,POWER,RCA,etc...) and then plug just the power back in and see if the TV turns on, and make sure when you take the power cable out, take it out from the back of the TV, when you plug it back in it should click.
If the TV powers up then try plugging in your HDMI cables and see if that works.
SOURCE: I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
SOURCE: We have a Magnavox, 50 inch plasma TV, model
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
