Question about Apple iPhone 4 Black Smartphone
How to bypass iPhone 4 icloud passcode
I cant remember the unlock passcode to my iPhone 4, and I don't have the original PC that I synced the iPhone to
    Sergeant:
  • 307 Answers
Ya can't, its an apple issue which previous owner has setup "find my iphone"
Posted on Mar 09, 2019
    New Friend:
    Problem Solver:
  • 19 Answers
You cannot bypass icloud.
Posted on Mar 08, 2019
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
ICloud password should be the same passwords as your apple id
Posted on Aug 13, 2014
4 Suggested Answers
Anonymous
SOURCE:
Tushar Khandelwal
  • 20 Answers
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
Posted on Feb 13, 2009
Anonymous
  • 14 Answers
SOURCE: iTunes cant connect/recognise my iPhone 3G
Hi Try and plug your iphone to another pc and see if the same problem is still there, if no problem is form your pc, other wise you are having a problem whit your iphone i would advise to send your iphone to repair to www.E-Repairs.co.uk
Posted on Aug 28, 2009
Anonymous
SOURCE: iPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
Posted on Jun 06, 2010
How do i bypass the apple id activation on my iphone 6?
iCloud Locked iPhone 6 How to bypass iCloud Lock on iPhone 6
So, in this post, I would like to show you 4 solution about iPhone activation bypass
Solution 1. Remove iCloud Activation Lock from your iPhone 6 with Unlock Tool
Solution 2. Bypass iCloud Activation Lock Software via iCL0udin
Solution 3. Bypass iCloud Lock via Apple Setting
Solution 4. Bypass iCloud activation online with iCloud Lock Removal Service
Sep 19, 2016 | iPhone Apps
How can I unlock a passcode?
If you repeatedly enter the wrong passcode, your iPhone will be disabled for longer intervals before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect it to the computer with which you last synced it [if it has been synced to a computer].
Note: You can configure your device to erase itself after ten consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock.
If you cannot remember the passcode, you will need to restore your device using the computer with which you last synced it [or iCloud]. This allows you to reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present.
Please also note that Apple representatives can't unlock an iPhone for you without restoring the iPhone, either. The restore process will erase everything on it.
Apple's official instructions to restore an iPhone with iTunes are:
  1. Connect your iPhone to your computer [that you have previously used to sync the device].
  2. In iTunes, select the iPhone in the "devicess" list, then "Summary" at the top of the screen.
  3. If iTunes doesn't automatically synchronize your iPhone, do so manually [and confirm that the sync and backup were successful.]
  4. Click "Check for Update." iTunes tells you if there is a newer version of the iPhone software available.
  5. Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you [again] backup the iPhone when prompted.
  6. When iOS Setup Assistant asks to set up your iPhone, choose "Restore from iTunes backup."
  7. Select your device in iTunes and choose the most recent backup of your iPhone.
After this process, your iPhone should be restored with the information from its last backup, but it no longer will have the passcode enabled. It would be wise to think carefully before setting another passcode or using the passcode feature again.
Apr 04, 2016 | Apple iPhone 4 Black Smartphone
My iPhone has disabled how do I unlock it
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - If you enter the wrong passcode in to an iOS device six times in a row, you'll be locked out and a message will say that your device is disabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't ... If it doesn't, learn what to do. Once the sync and ...
How to remove/reset any disabled or Password locked ...
? 5:31
https://www.youtube.com/watch?v=csLUmaDTHl4
Oct 30, 2014 - Uploaded by Karlos Corner
iTunes will alert you that it has detected a device in recovery mode. 6. .... easy and fast to activate/unlock/jailbreak/bypass every iphone from 5s to 6s without having any problems. use "newunlockiphone,net". .... +Clair Glen My iPhone is disabledfor 23,760,796 minutes. ... Do you need an ITUNES account?.
Top Ways To Unlock iPhone Disabled - YouTube
? 2:35
https://www.youtube.com/watch?v=KiWp28QTToQ
Jan 1, 2014 - Uploaded by CocTubes
How to Unlock Your iPhone When Its Disabled .... me use myfingerprints like it normally does. of anyone has anyway of helping.... What to do?
Dec 16, 2015 | Apple iPhone 4 Black Smartphone
How would i remove i cloud from a phone i bought and owner no where to be found
There is no known way to bypass an iCloud unlock unless the previous owner provides the correct credentials for the account in question. Performing a factory restore will not remove the lock since the lock requires authentication through Apple's servers. Hypothetically even if you could restore the device to a previous firmware, the lock will remain.
Oct 02, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Unlock i phone 5
Icloud Locked is forever the original owners. They have to remove it. www.icloud/#find Unlock the GSM for any sim, contact your carrier. Third parties can request an unlock for a nominal fee. Passcode issue try the link.
iOS Forgotten passcode or device disabled after entering wrong passcode
Jul 27, 2014 | Apple iPhone 5
Bought an iPhone 4, screen locked with passcode unknown, and synced to icloud
From the Apple Support site ...
Use restore your device as new or from a backup.
  1. Disconnect all cables from your device.
  2. Turn off your device.
  3. Press and hold the Home button. While holding the Home button, connect your device to iTunes. If your device doesn't turn on automatically, turn it on.
  4. Continue holding the Home button until you see the Connect to iTunes screen.
  5. iTunes will alert you that it has detected a device in recovery mode.
  6. Click OK, then restore the device.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Jul 11, 2014 | Apple iPhone Smartphone
I bought a iphone and the owner does not remember the passcode to unlock from icloud
reinstall software from iTunes and set up as a new phone. or on the phone go to settings: general: reset: erase all content and settings. takes a while if you do it directly on the phone!!
Dec 23, 2013 | Apple iPhone Cell Phones
Apple iPhone 4 Black Smartphone Logo
1,159 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
