Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
SOURCE: bosch 1400 exxcel
The machine thinks the drain is blocked.. check the pump and outlet pipe for buildup of dirt.
I noticed holding start down for several seconds whilst powering the machine on, then turning it off / then on again would clear the machine's idea of where it was during a program. Does this affect the error code you're seeing?
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
SOURCE: I have a bosch exxcel 1400 express and a key
check the manual . you can take the key mode off with the instructionsprobably a press and hold for 2-3seconds thing .If you dont have the manual you can get it from thermador. com they will order it for you. you will get it 2-3days. let me know how you made out:)
SOURCE: I keep getting error message F04
