did your vehichle completely run out of gas , if so after adding gas , it will take a short while for pump to pump gas to engine, also if you have a owners manual, look in it and look under fuel, to see if it show s a fuel reset button, if so, you will have to push the reset button to reactivate the fuel pump. sometimes , they are loacated at the right or left rear in side, or under the the right side of instrument panel.
To replace the fuel filter lower tank a little bit to unclip filter line from pump . Then remove
small bolt that holds filter in place then unclip from fuel line..
fuel pump is n the tank its not too bad if the tank is almost empty u may need a big big pair of chanel lock pliers some chryslers have a screw on cap thats about 6 in in diamater
12-direct battery input to PCM was disconnected within the last 50 key-on cycles 41-generator field not switching properly 55-end of error messages Check sparg plugs, ignition cables, fuel system (fuel filter, injectors)
