https://printcopy.info > code=C1-14
Code: C1-14 · Description: Main charger trouble (Color) · Causes: The main charger unit (CMY) is not installed properly. There is an abnormality in the main ...
The MX-2310U offers Confidential Printing, which when used, requires users to enter a PIN code in order to print a queued document. To help protect your direct-print documents from unauthorized viewing, the MX-2310U offers encrypted PDF printing and scanning. Additionally, Secure Fax Release ensures received fax documents are held in memory until an authorized user enters a PIN code, so that compliance with healthcare regulations such as HIPAA is easier.
This data will be cleared if Sim 66-10 is enacted.
Try this while you're at it.
# * C * to enter the simulation mode.
Simulation 66-10 is the image memory clear which clears the print/scan/fax memory. DO NOT EXECUTE AND OTHER SORT OF CLEARS IN THE MENU.
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
