How do I change the battery on a Samsung galaxy tablet
SOURCE: Hi, i m not able to find the motion sensor
its in notification panel by the name orientation lock.
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
SOURCE: have a samsung galaxy tablet
Have you tried holding the power button for 10+ seconds? or can you remove the battery?
Testimonial: "thanks tried holding power button longer but it workede thanks"
SOURCE: Samsung galaxy tablet is frozen
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
SOURCE: Can I reset factory settings on Samsung Galaxy tablet
This hard reset can be done even if the device won't seem to power on.
