Hitachi 43FDX01B TV Logo
D
Diligent Dan Posted on Jul 10, 2014
Why is the picture off center + no menu access
I don't know how this happened, but the picture is off center to the right cutting off about an inch, black vertical bar on the left side, and the menu will not pop up using the remote OR the TV buttons! Oh, there's also a ghost image over the right half of the screen. HELP!
5 Related Answers
Anonymous
  • 1284 Answers
  • Posted on Feb 01, 2007
SOURCE: picture off center
If you were in the technician menu then look for the HCENTER adjustment (horizontal centering) then move accordingly.
Bill Heronemus
  • 308 Answers
  • Posted on Feb 11, 2007
SOURCE: Hitachi Standard T.V.
Some of the problem could be a weak or damaged picture tube - especially if it encountered rough handling in the move. Other possibilities are bad capacitors in the power supply and deflection circuits which are common with this aged set. No adjustments come to mind that could permanently fix these symptoms.
Anonymous
  • 1139 Answers
  • Posted on Sep 21, 2007
SOURCE: no picture,no sound, no menu
This indicates that the shutdown circuit has triggered the shuting down of your TV. This could denote a problem in the low voltage or high voltage power supplies. I would suggest taking the Tv to the repair shop or having a tech come over to your place and give you an estimate.
Eduard P
  • 71 Answers
  • Posted on Dec 10, 2007
SOURCE: black square in middle of tv
He, he. Somebody activated the subtitle mode on the remote. Desactivate the CC mode on your menu and it'll go away or at least if you want CC put it in CC1 Text1
Anonymous
  • 1153 Answers
  • Posted on Dec 26, 2007
SOURCE: Re: Hitachi TV Model 42EDT41 42 Inch
panel defect
Adjust my 40 Samsung 1080p 120Hz LCD to see the entire picture. t is currently cutting off the edges; left, right, top and bottom
First check if your zoom is on..if it is switch back to normal setting. If picture is still cropped with no zoom then try go to the menu seen string and check for aspec ratio..try different sttings..
My 4x6 prints are not centered on paper
That printer can't print borderless on 4x6 photo paper, you should use A4 size paper, print and cut the pictures.
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
My camera doesnt work on my cu915 lg vu
have you ever taken pictures with it because that happens sometimes with me and it just means that my memory is taken up by having so many pictures
CONVERGENCE IC ADJUSTMENT
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Picture is off center to the left by 9.5 inches
you need a new light tunnle cost about £70 but whoever you get to replace it wil charge about £140 labour
Background
Hi Adrien, the easiest way to set a picture as a Windows background is to open the picture in your web browser and right click on it. A menu box should appear, about half way down you should see an option labeled *Set as Background*. Left click on that option and Windows will automatically use that picture as you background image and tile it to fill your entire desktop. Alternatively if you have Windows XP and use the Windows Picture and Fax Viewer program to display the picture the process is the same except when you right click on the picture the selection will be *Set as Desktop Background*. When you select that option it will do the same thing. If you don?t like the tiled effect right click on the desktop and select properties from the popup menu. In the display properties box that appears click on the Desktop tab, and in the lower right hand corner you will see a field labeled *Position*. Left click on the pull down arrow and select center or stretch, depending on what effect you want. Let us know if you need any other help and don?t forget to rate the posting.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
