After scanning my pen drive with smadav my computer can no longer detect it.
SOURCE: computer can't detect the flash drive
The use of USB on that different PC must have been disabled from the CMOS. Enable it by pressing Delete key upon booting to enter your cmos settings.
SOURCE: how to correct the input/output device error in pen drive
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
SOURCE: sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
SOURCE: win 7 does not recognize pen drive
Go to my computer, Removable Disk (E:), there you can open and add stuff to your usb, most computers dont recognize it.
