Belt diagram 2006 model 6605 can I get a picture?
I DON'T HAVE IT ON HAND, BUT YOU CAN TYPE IN ON GOOGLE SEARCH "YOUR MODEL # DECK BELT DIAGRAM" TO FIND IT, BUT TO DO IT YOURSELF, JUST REMEMBER THAT BLADES MUST TURN COUNTERCLOCKWISE AND THAT GROOVED PULLEYS MUST FACE THE INSIDE OF BELT AND FLAT PULLEYS THE OUTSIDE OF FACE OF BELT, ALSO REMEMBER THAT SOME MODELS HAVE JUST ONE BELT (DRIVE AND DECK BELT) OR TWO BELTS (DRIVE BELT AND DECK BELT)
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
SOURCE: Need help on replacing drive/transmission
I believe their is a plate between the seat and steering wheel. Unscrew the plate and you will see drive pullies, push in and lock brake, this should supply enough slack for you to reach under the seat remove old belt and install new. It is a real pain.If brake can not be locked you need someone to press it while you do the work. Removing the deck will really not help because you will not be able to reach transmission pulley under seat.
SOURCE: Deck belt broken, l need
Hi, You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic. Also you can check this link to download the diagram:- http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/ Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
SOURCE: I have an early-2000s Troy Bilt Bronco, 42 inch
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
