Maytag M7DH45B2A Dehumidifier Logo
A
Anonymous Posted on Jul 07, 2014
How do I empty my dehumidifier? - Maytag M7DH45B2A Dehumidifier
Dehumidifiers bucket empty but says full water leaking on floor
if says full and leaking on floor. it is full, you say empty, why make sure that it is empty, sensor in container to check level, so if it is empty, sensor fault, but leaking on floor, would indicate sensor ok, and container full
The float is broken in our dehumidifier, is it repairable?
Is the float in the empty or full position?? If it is in the empty position, and the unit will run normally, then yes you can. The water will divert from the evap tray right into the hose. If it is stuck in the full position, and wont run because it thinks it's full, you will have to find a way to put and hold it in the empty position.
Will not come on after resevoir was emptied
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
1helpful
Continuous Dehumidifier Operation issue
Unfortunately, I haven't been able to get the water from the dehumidifier to drain out the hose. It always empties into the bucket, which means I have to empty it daily.
Top Maytag Dehumidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
