Braun MR 5550 M HC + BC MultiQuick Professional Handheld Blender Logo
A
Anonymous Posted on Jul 06, 2014
I can not open the body of my hand blender 4191 to
1 Related Answer
Anonymous
  • Posted on Apr 04, 2010
SOURCE: I can not open the body of my hand blender 4191 o see what is the
i want open the body of my hand blender 4191
Replacement parts
Part 2: Opening up the Braun handheld blender/mixer turbo 600, typ 4191.
A second phase, with the Dremel for working in the direction of the axis and splitting up the tools mounting part, also showed that no other way was available to open the machine7be945c4-ba75-4b59-83da-fc638caa551e.jpg
5helpful
Looking for somebody to repair my braun blender in Cape Town
Part 3: Opening up the Braun handheld blender/mixer turbo 600, typ 4191.
The front end and the motor are a cast-joint part. With one more circumferential kerf, the grip-part came free, also showing that there is no other way to open the machine irreversibly.
It also showed that the contacts between the motor and the print are/were relatively loose, which amazed me for a motor of 600 Watt. And in my case: they were burnt. That explained the machine not working. It is surprising that the thermal safety didn't kick in when my wife used the machine
How to dismantle hand blender kenwood kmix?
hi there, i have one of these and am quite tech savvy and want open
the sucker up and see whats wrong. Just would rather open it with
minimum damage to the casing.
Is there a way i can private message you my email address?
thanks
Dan
5helpful
6helpful
Braun type 4191 blender shaft coupling faulty
I had the same problem, the authorized service told they cant fix it, so i tried it. First, I show you the solution:
You see the black one you attach the heads to. The axis come from the motor with the little teeths: the black plastic wore away that's why the motor works but the end doesnt rotate.
You can simply pull the black one out with a pliers with medium force and if you get a new one(thats the hardest, they wont sell you) that will works.
For the mankind, ive totally flatten out my type 4191, so i show you some pics, how to solve yours:
if you had problem with the motor, simply cut it half. You wont harm anything, the motor is in a metal cylinder.
If you have some promblem with the electronic part, its in the end of the blender. You can open it at the top, but you cant reach anything form there, nor here, sad story.
finally some photos from the bottom:
Enjoy it!
3helpful
How do i turn the bottom piece off the blender?
If it's like many other units, you can unscrew the bottom, BUT its a left-hand thread! (this is so as the blades spin colckwise, they don't unscrew the clear plastic body from the base if they trap stuff against the side).
28helpful
2answers
13helpful
3answers
How can I open akrups gpa3 blender.It does not work only 3 years
The body of the blender is held together by three cross head screws two at the base which are clearly visable and a third which is concealed by the pulse on/off switch which you need to prise off to reveal - small spring to rear to catch! Our blender went totally dead due to a blown internal fuse which I have now replaced and hey presto we are back in action.
14helpful
4answers
How can i open my hand blender
Unplug it first and with a flat-head driver prise open the top between the flex and the top.
45helpful
6answers
Braun blender 4191 motor part does not work. fuse is alright. cannot open the cover in order to asess the damage. please advise.
My GF broke our Braun handheld mixer type 4191 500W, trying to mix some figs, the mixer doesn't do anything anymore. I like the mixer very much. I poked a while trying to open it and look what is wrong. This is what i found to open it. On the top, where the numbers are to adjust the speed: remove gently that lid. Below that you'll find 2e lid with the numbers on (1-5), this you can get open by pressing inside the 2 holes with 2 little screwdrivers, push these 2 black tips away and the 2e lid can be removed. Unfortunately i broke my mixer up trying. Now it's open i see how it was. Good luck guys
Top Braun Blenders Experts
Mike Cairns
Mike Cairns
Amy Smith
Amy Smith
Are you a Braun Blender Expert? Answer questions, earn points and help others
