If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
String is wound clockwise when looking from the top down.
SOURCE: replace string on trimmer
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
http://www.youtube.com/watch?v=WFu66Q6J62Q
SOURCE: trying to replace the fuel line and the primer
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
SOURCE: how do you change a head on a poulan pro trimmer
Just below the gearbox there is a slot and when you turn the shaft there is a slot on the shaft that lines up with that one. Stick a screwdriver in the slot when they are lined up and then grab the head and turn it clockwise. (the threads are reversed)
My PP125 the string rolled back up inside the first time I used it and it was a solid piece of string. called Poulan they were no help and neither was Wally World. Any suggestions?
