I am trying to round bale with a John deere 7810, but the pto will not turn under load. If it is unhooked, the shaft will spin, but not when attached to the baler. Is this electrical? A hydraulic pressure issue or what?
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
SOURCE: my father in law has a 1980 410d john deere
did they rebuild the hydralic pump and if so they need to do it again and check the valves in it
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
