How do I prevent my washer from eating socks?
SOURCE: Top load whirlpool washer
you don't remove the 2 screws on rear of console lift and roll console back remove 2 brass colored clips on eack corner remove lid switch plug pull cabinet forward and off
SOURCE: My Whrilpool Duet keeps
That is a common problem with the Whirpool duets. Small clothing articles, especially baby socks go through the drum lip to the drain pipe.
Best to buy a zip-up laundry bag and place all the small clothing items in there.
Best Regards
Ash
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
SOURCE: Whirlpool top loading washer, spin cycle just quit.
From the symptoms you describe, it sounds like you may have a broken motor coupling. The coupler is located between the drive motor and gearcase (transmission). It takes the place of a drive belt. This configuration is known a "direct-drive". The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
Replacement couplers are improved and more resilient to resist breakage. The part number is included in the link I provided. You can purchase one at appliancepartspros.com for about $11.
If you have any questions about this repair, please let me know. I hope this helps you.
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
