SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
SOURCE: i have a john deere 325 with a kawasaki 18 hp v
Try adjusting the deck height up a little or start a the carb.
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
SOURCE: need to reset my oil service light on my john
Hi and welcome to FixYa. I am Kelly.
The light (blinking notification on digital read out) will come on 1/2 hour before and remain on for 1/2 hour after the interval. If you pass your model number I can paste the notification data. It is NOT re-setable.
How Does Your Hour Meter Function? Model Year
Model Number and Product Identification Number Groups. Is the tractor equipped with an hour meter? Does it accumulate hours with the key switch left "ON", but not running? How long does the service reminder (SVC) display before and after service intervals? Does the Hour meter stay lit or display hours when the key is in the" OFF" position? Does the hour meter only count hours when the engine is running?
2008 - 2011 D100 D110 D120 D130 D140 D150 D160 D170 LA105 LA115 LA125 LA135 LA145 LA155 LA165 LA175 Yes No half hour No Yes
^- This was a chart... It did not pst well at all. The key is that the interval underlined above is 1/2 hour before and after the service due period and it is NOT resetable.
Thanks for choosing FixYa,
Kelly
SOURCE: on john deere 345 18 hp kawasaki liquid cooled
Water pump gear or the water pump impeller could have failed. If its the pump and due to it being at the bottom front side of the engine it would take some time for it to boil due to the fan is always pulling air down thru the radiator and its at the very top of engine. Cool water on top and really hot coolant around the cylinder with sensor. I'm sure it's the pump.
