The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction in the lid lock area. Please check the lid lock area and remove any objects in that area.
Jun 22, 2021
Never heard of the make 'Haam"? Perhaps you mean 'Haier'? Anyway, it might be a generic drain error
An E2 Error code indicates that the washer is still draining after 8 minutes. Check the following: Check that the drain hose is not more than 391 ?3" (100 cm) from the floor. Remove any clogs from the drain hose.
The E2 code is a water supply error.
The water inlet valve has stopped working.
Try going here...
appliancepartspros.com
with the model # and you can look up the part and how to put it in.
Tis not hard. A phillips & flat blade screwdriver and some pliers.
If it is E2 15 then it may be a switch error (Main Relay error) Check for stuck button switches or power button switch for sticking. May need to replace the main PBA. Verify the error and provide the model number to verify the error code specific to your model.
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement .
you can get new motor at
www.repairclinic.com
The machine beeps E2 all the time. Actually E2 error code means washer door is not closed properly. However washer door does close properly, but the machine still beeps with showing E2 error code. Please help solve this problem.
