U-Line U Line 2000 Series 2175BEVCS00 24" Built-in Beverage Center with 5.6 cu. ft. Capacity, 2 Glass Beech Wood-Trim Wine Racks, Single Zone Convection Cooling and CEE Tier I Energy Star Qualified: Stainless Steel/Right-Hand Hinge Logo
W
WalterB Posted on Jul 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Popped a circuit breaker and when I reset it, everything but the uline wine fridge came back on. Tried all the troubleshooting ideas in the manual
jabberwoky
Level 3:
  • Master 739 Answers
  • Posted on Jul 05, 2014
jabberwoky
Master
Level 3:
Answers
739
Questions
0
Helped
229586
Points
3082
Sounds like you 'smoked' the transformer.
ULine U-2115WCS Wine Fridge flashing "ER" after temp.
Question edited for clarity.
Question moved to a better category..
The Thermistor has failed or is failing. It is the temperature sensor that is basically your electronic thermostat.
Troubleshooting Guide: U-Line Refrigerator Error Codes U-Line refrigerator troubleshooting begins with cracking the codes. Let's take a look at U-Line brand error codes.
Error Code ER
Diagnosis: Thermistor 1 is open
Explanation:
The U-Line refrigerator error code ER is alerting you to a failed thermistor. Thermistors are used for various temperature readings. These provide reliable temperature readings using a resistance which varies based on surrounding temperatures. If you have a U-Line wine cooler, for example, it will include ambient temperature surrounding the refrigerator unit.
If the thermistor 1 fails, the refrigerator will continue to operate on a preset 10 minutes on and 30 minutes off time interval.
Solution:
Use an accurate ohm meter to test the thermistor. If the thermistor is defective, have it replaced.
https://www.google.com/search?q=uline+u-2115wcs+thermistor
Uline wine fridge 2075-wcs not cold enough
Check condenser make sure it is clean then listen to see if condenser fan motor is running . if compressor is running cuntinuesly and other mentioned are ok it could be low on Freon
The electricity went out for a SECOND yesterday, and the fridge has NOT come back on. Yes I checked the breakers and they are all on. Please help... thank you.
Would really need the exact make, model and year to investigate the problem more. However, try turning off the circuit breaker for at least 5 minutes and turn it back on. Does your light inside the fridge still work when you open the door? If so, you may have a little red reset button on your compressor motor that is popped up and needs to be reset by pushing it back down. If not, test that your circuit breaker is still working correctly. One quick check for the circuit breaker is when it is flipped on does the breaker switch rest firmly against the "On" position side of the breaker? If it feels like there is some play or slop between the switch and its "On" position then the breaker needs to be replaced. Let me know if any of these where the issue.
I,ve got an Briggs and Statton elite 10000 watt generator, it wont supply enough power to the house evrything is dim lights etc, Ive used it amny times before it will pretty much run the whole house...
Does it appear to be running as fast as it always did, as in RPM's are same as usual? If there is a fuel problem and rpm's decrease due to that, voltage will drop as well. Other causes may be internal problems with generator circuits etc, and will need technician to troubleshoot it properly.
You can try increasing the throttle manually and see if voltage comes up.
Maytag fridge trips circuit breaker
replace the ptc overload relay on the compressor,it merely unplugs,it supplies start and run power to the compressor and if its bad it will allow the compressor to operate on the start windings too,and draw a lot of current
4helpful
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
2answers
GARAGE FRIDGE DIED...IS IT THE COLD?
No it has no sensor it sounds like the circuit breaker has tripped or the is no power at the plug..try plugging a radio or lamp in to the plug to test
Top U-Line Wine & Spirits Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Don A
Don A
Are you an U-Line Wine and Spirit Expert? Answer questions, earn points and help others
