Indesit W 123 Front Load Washer Logo
A
Anonymous Posted on Jul 03, 2014
Samsung broken door handle - Indesit W 123 Front Load Washer
My freezer door handle has come away at the top how can i fix it mysel
If handle is broken get a new one and by removing inner door panel install the new one. Parts available at attached link Search Over 2 1 Million Appliance Parts
The door handles on my Samsung french door refrigerator are very scratched up. The handles are not broken so all I need is the black paint.
Make sure you use appliance black paint. But before you remove and paint the handles, compare the color for color match- not all black are exactly the same. Color can differ with brands.
Samsung wf8702rsw
Contact the manufactures web site and request the needed information through their customer support. There should be a link at the very bottom of the web page.
4helpful
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
1helpful
Broken freezer door handle
Fairly easy repair, go to www.searspartselect.com and you can get a illustrated diagram of the machine and how it comes apart
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
10helpful
2answers
My samsung SMH7187STG microwave handle broke off.
You can order new "cap handles" (the plastic parts that join the aluminum handle to the door for 3.99 each plus 8.99 shipping and handling at the Sears Parts Direct Website. The part number is DE67-00222C. When you have the parts in hand, open the microwave oven door. On the inside surface of the door their is a black plastic frame around the door that pops off easily (gently use a screw driver to pry up the door frame) so that you can have access to the screws that attach the end caps to the door. You will need to hold the remant of the cap handle (the part that is probably broken off even with the glass surface on the outside side of the door) still while you unscrew the screws. Once the screws and broken remnant of the handle caps are out, you are ready to put new handle caps on the handle, then put the handle with the new handle caps on the door. By the way, Samsung was absolutely NO help with this. The agent I chatted with denied that their were any reports of the handles breaking off, so I had to cut and past the postings about the door handle breaking off ON THEIR OWN WEBSITE under "Community Q and A" into the chat box -- still the agent did not acknowldege the existance of these reports...or the possibility of a poor design. I asked for them to send me a couple of the $4 parts as a good will gesture....got nothing but lofty words about Samsung commitment etc. and only a authorized technition blah blah, no action. All you need is a strong thumbnail, a phillips head screw driver, new handle caps.
1helpful
Driverside door handle frame is broken and cannot open the door
check handle is ok or broke
check behind handle shaft if it is came out from- handle point
Broken door handle on a samsung j845 washing machine. i need a replacement.
http://www.pcappliancerepair.com/
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
try these two places to order the handle. You will need the complete model number ,
from the sticker in the washer door jam
Please remember to give me a good rating
2helpful
Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
