JVC AV-32D305 32" TV Logo
A
Anonymous Posted on Jul 03, 2014
Jvc tv 50d501 will not turn on
Power will not stay on
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on May 14, 2009
SOURCE: AV 50D501 JVC projection T.V.
This problem is usually generated from one of the three guns used to generate Red, Green , and Blue. When the over load circuit detects to much current it shuts the unit down. Ohm out each gun and see if one reads higher then the others. RW
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
MY AV-50D501 shuts down as soona s i try to power it on. The power light will come on for a sec and click but shuts down immediately thereafter
The main board to your TV should be troubleshooted, especially to its horizontal output section circuit; for any shorted component/s. Seek support by any experienced service technician.
104helpful
4answers
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
1helpful
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
25helpful
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
3answers
sounds like a bad connection in the deflection circuit. you need a repair tech
2answers
Jvc av-50d501 parts search
I'm looking for a prat number 930B8750-01 it is a tuner controler.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
