JVC AV-27230 27" TV Logo
A
Anonymous Posted on Jul 03, 2014
JVC AV32R25EK dark picture - JVC AV-27230 27" TV
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
I have jvc replaced bulb but picture is still very dark if not bulb then whay would cause the dark picture not bright or vibrant
Problem could be in the Light Engine and it may need to be replaced. which is also known as the optical Engine PN# TSCOP7A-SAA
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
JVC GD-V425PZW no Picture
motherboard needs replaced, to test take a flashlight TV on and shine on screen from above at an angle, do you see a faint image, replace MB
3helpful
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
