SOURCE: Kitchenaid KHMS155lss-2 Does not heat up, I now
there are 4 things that you can check if you are able to do some electrical tests the diode the capacitor the hv filter capacitor and the magnetron .This is extremely dangerous to work with this high of an amount of electricty and if you are not familiar with these tests i do suggest you call a techncian click here to find how to discharge the capacitor http://www.gallawa.com/microtech/safety.html#dischg
first thing to check would be to see if the microwave is fitted with a fuse this is one of the most common problems for the ones that do have fuses some models do not come with the fuse so if you dont see one dont worry about it .open the casing of the micro wave and look at the rear right for the hv diode it is located next to the power supply and is identified like in the following link http://www.donberg.ie/pics/s/scl_11z-2.jpg. check the diode for any physical damage like a crack , bulge , burst or burned smell this would be a common issue if this were the problem as well to test set a multimeter to resistance at 10k ohms a normal diode should read 50-200k ohms. Next component to check is the HV Filter Capacitor. This component is a big circular steel tube on the board/mounted near the HV diode MAKE SURE YOU DISCHARGE THE CAPACITOR FIRST. Set your multimeter to the highest available setting when connecting to your test the test should read infinite. The reading should go to almost zero and then go back to infinite.also inspect the capacitor for any bulges leaks or cracks or a strong burnt smell these capacitors are made to fail .If neither the diode the capacitor nor the fuse(if you have the fuse) is faulty then you would have by process of elimination end up at the magnetron you can find the magnetron at www.marcone.com under contact us there is a 1800 number and you can find the diode and the capacitors at any electronics supply if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future in similar situations Thanks Rick
SOURCE: Kichenaid microwave khms155lss-4 doesn't work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
