SOURCE: whirlpool duet how to enter diagnostics
look for tech sheet. this will tell you how to enter machine into service mode. Its located either behind bottom kick panel. or under top panel.
SOURCE: My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
SOURCE: how to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Testimonial: "Thanks for the info!"
