Blades keep coming loose
SOURCE: I have a craftman 42 in dual blade riding mower.
Either the deck is uneven or one of the blades are upside down
SOURCE: When I engage the mower blades, the tractor tries to stall
Besides the reverse switch, the seat switch will also cause this.
SOURCE: How to remove blades on craftsman lt2000
There usually bolted on from underneath you must have a wrench are set of wrench to take off. Most models are some times kinda hard to get to
SOURCE: I have a Craftsman LT2000 tractor and I've had a
the pulley that the disingage spring is hooked to sounds like its freezing up it may need some oil put on it to make it slide easier
SOURCE: lever won't engage blades
check to see if a belt came off, it would go from bottom engine pully to deck lever pully then around blade pullys on deck. the pully under neth has to tighten belt to run blades the pully is ether solid to lever or has a cable that moves it make sure cable did not break hope this helps
