SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
SOURCE: reset drum unit counter brother
Press the "Go" and "+" switches together until the menu "RESET
PARTS LIFE" appears on the LCD display. Select the Drum Unit using the "+/- " switches, then press the "Set" switch
