Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
27hp liq cooled kawasaki engine dies after it reaches running temp
2 Suggested Answers
SOURCE: 09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Posted on Jan 08, 2010
Testimonial: "thanks"
nova2nv
Bill Linda Rivard
  • 197 Answers
SOURCE: on john deere 345 18 hp kawasaki liquid cooled
Water pump gear or the water pump impeller could have failed. If its the pump and due to it being at the bottom front side of the engine it would take some time for it to boil due to the fan is always pulling air down thru the radiator and its at the very top of engine. Cool water on top and really hot coolant around the cylinder with sensor. I'm sure it's the pump.
Posted on Jul 19, 2011
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
When my 1991 Isuzu trooper reaches normal oper. Temp. It dies and I have to wait till it cools down and it will start right back up and go some more till it reaches temp. Again. Runs great cold but when at...
model with coil fitted check this as when they over heat they stop sparking. also the spark plugs and leads, up graded model with electronic timing check the dis pack and then the spark plugs and the leads, leads can check with meter, if hard or stiff leads replace them as this can mean they will crack with engine movement. check spark plug gap to your recommended speck for your engine code. coil should be replaced every 5 years or depending on your driving times these can very depending on coil fitted. dispak type if it has any cracks in the casing replace as water could of damage the internal coil.
Dec 21, 2017 | Cars & Trucks
93 honda accord shuts off after reaching temp
I had the same problem with my accord years ago and it turned out to be that the ignition module would die whenever it got hot and then start working again when it cooled off. It is located inside the distributor and costs a bit less than a whole new distributor. I changed the entire distributor, to be sure all the ignition components were new and would not fail again for a while.
Aug 06, 2012 | 1993 Honda Accord
1993 S-10 Blazer runs great then dies at temp
If you have Code 15, you need a volt meter or you will run into a wall. You measure the coolant resistor ohms when its cold then measure it when the engine is warm.You also have to measure one side for a 5 volt reference.Or better yet when the vehicle reaches operating temperature and begins to stall take the leads of the coolant temperature and jump it together.This tell the ECM your temperature is 266F. If its stays running and doest stall replace temp sensor
Mar 10, 2012 | 1993 Chevrolet S-10 Blazer
Hi
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
60 people viewed this question
Top John Deere Garden Experts
Joseph Mueller
Joseph Mueller
john h
rjivaro
Are you a John Deere Garden Expert? Answer questions, earn points and help others
