The neutral safety switch on an automatic transmission (also known as a park/neutral position switch or neutral start switch) is usually mounted to one side of the shift lever (top of the transmission), around the base and near the bottom (front-wheel drive models); other models have the switch attached to the left
Low fluid will not cause it to do that, If it pops out of gear you got a (Serios) Problem i hate to tell you, End on a (BMW) count on paying $2500 end up to have it (Rebuilt) Thats what you get for buying a (Over) price toy.
the belt from the transmission if it is slipping because of broken spring is right under the seat you will see the pulley on a arm that spring goes from that arm to the side of the frame i wish you luck take your time it is not that hard putting the belt back on takes more skill.
You can download a manual for the OM-1 from http://butkus.org/chinon/olympus/olympus_om-1/olympus_om-1.htm
The OM-1MD is the same camera as the OM-1 with the added provision for taking a motor drive to advance the film automatically.
The OM-1n is the same as the OM-1MD with a redesigned film advance lever, a flash ready/sufficient flash LED in the viewfinder, and automatic X-sync regardless of the position of the FP/X switch, when it is used with a T-series flash unit mounted on Flash Shoe 4.
There is an idler pulley inside the deck with a spring. The belt probably jumped of the idler which would result in the drive cable being slack. You can probably fix this yourself by re-routing the belt so that the idler with spring engages the belt. Depending on the condition of the belt you may have to losen all of the engine mount bolts so re-route the belt properly. I have had to take out all but ONE engine bolt (left loose) to install a belt.
If you need details on bolts / covers that need to be removed I need the whole model number to be of further asistance.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer: http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
You should be able to see where the springs attach by looking at the base diagram.
Following also is the Whirlpool / Kenmore PDF on how the transmissions work but it also has a good diagram of where the springs attach.
THIS MODEL DID CAME WITH ELECTRONIC THROTTLE CONTROL TO DRIVE THE RPMS ACCORDING WITH THE SPEED OF THE VEHICLE,AND IF DOES THE SAME THING IN REVERSE HAVE TO VE SOMETHING RELATED WITH ONE OF THE CABLES OR MECHANISM TO DRIVE THE THROTTLE BECAUSE REVERSE IS DIRECT GEAR AND NOTHIG TO DO WITH SLIPERY CLUTCHS IN THE AUTOMATIC
If the transmission whines, the brake may be sticking. you may have to relocate the brake return spring, to the rear of the flange that the spring is currently attached to
