Question about Pride New Mobility Legend 4 Wheel Scooter
Re wire pulse scooter - Pride New Mobility Legend 4 Wheel Scooter
Where is the battery fitted on the pulse scout 49 scooter
The battery on a pulse scout 49 is located on the floor between the seat and the steering under the mat you rest your feet on.
Aug 12, 2017 | The Health & Beauty
My Pulse Scout 49cc takes about 10 kicks to start in morning ok on electric start
Hi, Michael and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
10. Enricher valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Hard starting scooter 49ccScoot com Scooter Forums
Troubleshooting Your Scooter
http://www.scooterunderground.com/knowledge/manuals/documents/JetEuro50_Service_manual.pdf
Tao Tao 50cc Scooter Won Start SOLVED REPLACE CARBURATOR
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 18, 2016 | Motorcycles
What does the controller control? how? for what purpose? i'm in the u.s.a. :)
the controller depending on the wig wag resistance value , (the right or left hand paddle is pressed) will output power to the brake then the motor allowing the scooter to go forward or reverse...
The controller carries out a diagnostic sequence before proceeding to supply power to the motor, some scooters will flash the tiller led or bleep,,, Now the controller when put in reverse mode will send a pulse of voltage to the bleeper...
Regards
Dec 30, 2014 | Pride Go-Go Sport 4-Wheel
Scooter wiring diagrams
the wiring digrams are pretty standard on scooters. do a search for "scooter wiring diagrams"---you'll find dozens of them.
Jul 03, 2014 | 2009 Genuine Scooter Buddy 125
Wont move battery light pulses and battery indicator shows full cherge
you may have got some of the electrics wet, if so it should dry and be fine, if not then we need to know how many light segments are lit, and how many flashes.
Nov 30, 2013 | Pride Mobility Products Pride Legend XL -...
Cam timing for Pulse 150 scooter
wat was the question ..are u asking for pulsar 150 cc bike or scooter
Oct 29, 2013 | Motorcycles
Need owners manual for DP pulse strider 2600. Can't get display to work.
Hi,visit the website of your product & ask for 1 to be posted or you may be able to download 1 as a PDF File.You can also visit a scooter repair shop,i,m sure they will order you 1 for a fee.I hope this has helped,Colin
Apr 01, 2013 | Health & Beauty
Scooter stalls
Hi, the wiring must loose around the key switch, it might be a case of taking the tiller off and resoldering the wires onto the key switch. It not a major repair , just a case of getting the tiller panel apart and locating the wires to the switch.
Regards
GeWiz.
Sep 18, 2008 | Golden Technologies Companion II Travel...
Pride New Mobility Legend 4 Wheel Scooter Logo
65 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
