I've had this unit running great for 3yrs in my basement. Recently, there is ice build up on the coil and it does not reduced the humidity. The room temperature is always 62-70 degrees F and the unit runs on a shelf 5ft high. The dehumidifier is set to 60% humidity. I've tried to turn off the machine, let the ice melt and turn on again. Every time the ice builds back up and doesn't reach 60%. Please help!
Good Afternoon Miguel,
I understand that your Frigidaire dehumidifier, model# LAD704TDL, is not reducing the humidity, due to the coils constantly freezing up. I also see that it is located in good temperatures and in a good position. I suggest contacting the manufacturer directly. They should be able to point you in the right direction to having your appliance fixed. Hope this is helpful.
-Best Regards-
WP
SOURCE: Ice on dehumidifier coils
most likley low on freeon gets colder when it leaks out stat could be not working correctly
SOURCE: Dehumidifier switching on and off, a lot
Check this page:
http://forum.doityourself.com/archive/index.php/t-308629.html
SOURCE: Dehumidifier doesn't draw in water (humidity).
It may be too cool in the basement for it to work. Mine doesn't work if its 67 or below. Take it upstairs and see if it works there, where it is warmer.
SOURCE: Ice forming on the coils of my Crosley Conservator dehumidifier
Dehumidifiers freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
SOURCE: I have a 2 year
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
