Watches Logo
A
Anonymous Posted on Jul 01, 2014
How to reset Festina back to zero
How to reset the dial back to zero
Anton Taljaard
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2014
Anton Taljaard
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2182
Points
Pull out the crown, push the chronograph start button. You will see that the hand moves one second. once it is back to zero push back the crown. Depending on your model you might need to pull out the crown with one click for the chronograph timers and another click for the second hand.
  • Blinky San
    Blinky San Jun 21, 2016
    Spot on! Thank you very much Anton
  • Blinky San
    Whould you by any change know how to take off the glass to clean it?
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 • Watches
How to set a 3 dial watch to twelve o clock
click on this link, then click on instruction manuals in search box put F16162 then press search for instructions manual,,,please rate me if helped.
http://www.festina.com/
Hello there, How do I fix the zero positioning of the second hand (the small one below) of my Festina 16363 watch? Thank you!
It is possible to correct the zero error of the smaller dial. But the watch needs to be opened and fixed from inside. Since watches are very delicate and need special tools and experience, it is advised that you visit you local watch fixer.
Mar 01, 2011 • Watches
1helpful
I AM DAN FROM ROMANIA.MY CRONOMETER NOT STAY TO ZERO,IT STAY ALWAYS TO 29 WHEN I PUSH RESET.CAN I SOLVE MYSELF THIS PROBLEM,WITH YOURS HELP?
You can get instructions on page 20 of the instruction manual for your watch.
Go to http://www.festina.com/descargas/manuales/IFMOS80.pdf. The instructions seem clear=, so you shouldn't have any trouble following them.
3helpful
Large second hand not running, Stop Watch function?
Hey, it sounds like your watch is just fine! A nice watch to inherit.
The small second hand on the sub-dial is your normal second hand.
The large second hand is the second timer for your chronograph feature.
It should only move when you hit the side buttons. One of them (usually the top plunger/ button) will start the Chrono timer and then hitting it again will stop it. The bottom button should reset the hand to the 12 o'clock/ zero marker.
If the large hand is not functioning at all then there may be something wrong with the watch; perhaps the buttons are not making full contact within the watch or the hand may be stuck and need repair.
Hope this answers your questions. Post more questions if need be.
Congrats on your new watch.
8helpful
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 • Watches
16helpful
2answers
Adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
1helpful
Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Top Festina Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Festina Watch Expert? Answer questions, earn points and help others
