My washer stays in the agitate cycle...the timer doesnt move on its own automatically into spin and drain..what is the solution?
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
SOURCE: 98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
SOURCE: kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
SOURCE: kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
