Fan and motor not running
SOURCE: a motor fan running.........is not the fan
It is easy to replace. Just unplug the unit from the wall and cut the wires. Just two wires. Fan blades just unscrew from center. Should have a housing holding the motor in place. Does the fan run at all? Is it very noisy? Squealing, maybe vibration. ken
SOURCE: Evaporator fan did not start running when condenser fan started.
I don't know why there would be much of a delay between the condenser and evaporator fans coming on. If you have diagnosed it as a bad motor, that's probably correct.
But the motor could just need cleaning and lubricating
SOURCE: uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
SOURCE: my refr. comp. is runs but the evap.fan motor do not run
Look inside the freezer at the back panel. Is it covered with ice? If it is you most likely have a bad defrost heater and the ice has stopped you fan. If not you will need to replace the fan
Please rate this solution if it is correct. Thanks.
SOURCE: My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
